Analog electrical tester
Started by skipskip, January 15, 2018, 11:39:42 AM
skipskip
heavy duty insulation
accurate scale
safe for  all applications
What is is for?
coil/spark?
DSCF8283 by Skip Albright, on Flickr
DSCF8285 by Skip Albright, on Flickr
lptools
JoeCB
Is that a glass tube with a visable "spark" gap? If so, it's spark tester, for ignition systems.
Joe B
john k
I can see this in use on a flathead engine.  Long spike grounds to the head, short one pierces the spark plug boot.   Used to be a lot of problems with high resistance plug wires, a problem that has gone away.
bill300d
Quote from: john k on January 15, 2018, 10:51:33 PM
+1 What I was thinking too.
Bill Houghton
And testing the resistance in the plug wires used to be a standard step in doing a tuneup - back in the days of points and condensers.
p_toad
 :tongue:  Back in the day (before i had a timing light and dwell meter), i used to just tune up my '64 Mustang by replacing parts and then listening as i made adjustments.   Somehow i don't think that would work now.
