It's happended before, t'was bound to happen again... (short story)
Started by KeepinOldBolts, November 18, 2011, 10:31:38 PM
KeepinOldBolts
..some small part goes SPRroooooiing and you wait for the tiniest sound of it hitting the floor (or wall, or ceiling) to try and narrow your hunt in that direction.
I knew better.
Disassembling a SK ratchet, I had not been in there before and there is a small pin (spring loaded of course) just WAITING to be released from its prison. It pressures the reversing mechanism to toggle. How was I to know it was in there? Well, it launched (I heard it), but didn't hear the resulting landing Dang! I saw it left a tiny greasy spot on my shirt that in my mind reassured me it had lost some momentum and might be on my left side.
15 minutes of searching, I was about to give up. I had painstaking gone through the trash bin which was nearby. Nope. I started moving equipment (I knew better than that)..nope. 30 more minutes of flashlight aided, magnet assisted searching....nada.
Taking a quick water break, I resumed the search. Right as I was walking up to the work bench I looked down.
Bingo!
Just goes to show, if you work with small parts.......please....try and keep them contained!
johnsironsanctuary
When I disassembled the Williams SUPERECTOR to photograph the innards, nothing went sproing when I opened it.  I took the two little conical springs out from behind the ratchets very carefully. I set them aside while I cleaned things up inside the wrench.  I did all this on a mini bench that clamps in my big bench vice. It brings thing up closer to trifocal eye level and doesn't require a major archeological dig on the main bench. When I started putting the ratchet back together, one of the springs was not to be found. I dumped the trash can and wound up cleaning about 25 % of the shop looking for it. About an hour went by. I moved the big wrench and there it was, hiding under the wrench. By noting that my shop was a bunch cleaner, my attitude improved a bit. Point is, I think it happens to all of us who are not obsessive about shop neatness.
If a cluttered workbench is a sign of a cluttered mind, what is a clean workbench a sign of?
amertrac
When my shop was a working shop I bought four different assorted springs running from tiny to about 1 in. there were supposed to have 100 springs in each paper bag .i got a clear plastic shoe box with a cover to store them in . I opened each bag and emptied them carefully into the shoe box . put the box on the  top shelf where they would be safe.About  the second or third time i looked into the box for a spring I stood on a milk crate and reached for the box. This was about four years ago and I feel that what happened next had a lot to do with me finding springs this past fall when i cleaned the garage. I would not bet anyone against finding more today.
  bob w.
rusty
I once made the mistake of prying up the little fingers that hold the cover on a chevy ignition switch. All the little balls escaped merrily bouncing off various walls and things....
I handed the switch back to the fellow who owned it and just said...:I guess I'm buying you another one of these"
