Author Topic: ...with a wrench  (Read 2191 times)
...with a wrench
« on: January 08, 2012, 06:29:31 PM »
What can you combine with a wrench to make a tool?
Apparently, just about anything....
Some interesting patent titles...
01478651    Combination holder, wrench, and clamp
D0175853    Combination knife and wrench set
01393028    Combination monkey and pipe wrench.
02173215    Combination plier and wrench
01823494    Combination plier and wrench
00744167    Combination pliers and pipe-wrench.
01498844    Combination pliers and wrench.
02007432    Combination screw driver and socket wrench tool
D0172226    Combination socket wrench and screw driver
03850057    Combination torqueing and ratcheting wrench
02273982    Combination wrench and die starter
01402311    Combination wrench and pipe cutter.
01449486    Combination wrench and pipe cutter.
01405232    Combination wrench and pliers.
01522695    Combination wrench and pliers
01472312    Combination wrench and pliers
02000012    Combination wrench and pliers
02184340    Combination wrench and slide feeler
02616319    Combination wrench and vise
00254643    Combined axle cleaner and wrench.
00742914    Combined bolt-holder, wrench, and bolt-extractor.
D0167868    Combined case and wrench set unit
00283714    Combined clamp-handle and wrench for hose.
01660836    Combined claw hammer and wrench
00274420    Combined die-plate and tap-wrench.
01559919    Combined extensible wrench and pliers.
01422308    Combined friction and spanner wrench
00064662    Combined hammer, screw-driver, and wrench.
D0167920    Combined jar wrench, can punch, and
00292710    Combined jar-wrench and can-opener.
00089723    Combined lifting-jack and wrench.
00288095    Combined nut and pipe wrench.
01468211    Combined pipe and nut wrench
00738444    Combined pipe and nut wrench.
01461522    Combined pipe and nut wrench.
02854216    Combined pipe holder and wrench
00514000    Combined pipe wrench and cutter
01138395    Combined pipe wrench, cutter, and die
00282256    Combined pipe-tongs and wrench.
00494310    Combined pipe-wrench, monkey-wrench, and flange-holder.
01504401    Combined pliers and wrench
01817988    Combined pliers and wrench
01453145    Combined ratchet wrench and tool holder
00245603    Combined saw-set and wrench.
00081970    Combined screw-driver and wrench
02651229    Combined socket wrench and nut-ejector
01722723    Combined tack handle and tire-lug wrench.
00900556    Combined vehicle jack and wrench.
01557713    Combined wheel holder, lock, and wrench
01496716    Combined wrench and chisel.
00253549    Combined wrench and drill.
01935131    Combined wrench and gauge
02901934    Combined wrench and marking device
00270356    Combined wrench and pinchers.
00305495    Combined wrench and pipe-tongs.
00234540    Combined wrench and screw-driver.
00285902    Combined wrench and stretcher.
02640382    Combined wrench and wedging tool
01442083    Combined wrench and pliers
00266310    Combined wrench, vise, and nail-puller.
01405207    Combined spanner and wrench.
D0053569    Design for a combined wrench and screw-driver
D0024773    Design for a combined wrench and spanner
D0138515    Design for a combined wrench and spanner
D0054461    Design for a combined wrench and spring-leaf oiler.
D0053969    Design for a combined wrench and tire-tool.
D0121082    Design for a combined wrench handle
D0103914    Design for a combined wrench stand
D0076122    Design for a combined pole-line wrench and hammer.
00037920    Improved combined wrench, scraper, and screw-driver
00118617    Improvement in combined bushes and wrenches for bungs.
00133325    Improvement in combined clamps and wrenches.
00095706    Improvement in combined pipe-tongs and wrench.
00096776    Improvement in combined screw and pipe-wrench.
00203701    Improvement in combined vise wrench, and pinchers.
00137129    Improvement in combined wrenches and grappling-tools.
00067987    Improvement in wrench and pruning-shears combined.
00097877    Improvement in wrench and saw-set combined.
03575069    Ratchet and speed wrench combination
02372269    Theft resisting nut and wrench combination
Offline ray
Re: ...with a wrench
« Reply #1 on: January 09, 2012, 08:08:30 AM »
When I worked at the truck plant, working on spot welders,we would take a pair of 410 channel lock pliers and weld a hammer head on the back of one jaw, grind one handle into a straight blade screw driver and weld a phillips head tip of the other handle.
We used these to remove the welder tips with the pliers and then flip the pliers over and hammer the new welder tips on.
ray
« Reply #2 on: January 09, 2012, 09:20:54 AM »
When I was service manager for a C&D battery distributor in the 70's, I spent a week or so in the GM plant in Janesville, Wis. Line down time was so expensive, $10,000 a minute, that maintenance had a crash drill sequence with a number for every line down condition. They built line down repair trucks on heavy duty one ton Cushman trucks. When the assembly line called in a '126', a specific crew jumped on the little trucks with sirens and red lights flashing and headed for the line knowing what they had to do when they got there and what parts were needed. The plant was a mile long and they really moved right along. The maintenance chief had a stop watch and there was hell to pay if this '126' took longer to fix than the last one. Sometimes it was comical because of the union  divisions of jobs. An electrician unplugged it, a mechanic took it apart, a welder welded it, a steamfitter replumbed it and so on. Each one had his own crash cart and there was a great deal of excess labor on the scene. There were a lot of shop built tools on those trucks that were built because time was so expensive. Vise grips, C clamps and channel locks were the basis for most of them.
« Reply #3 on: January 10, 2012, 10:45:52 AM »
 Nice comprehensive list Rusty. Looks like you put some time into it. I have one more; its a wrench with a saw blade. Don't know for sure that its patented believe it is but it is unmarked and I haven't found patent for it.
