Mistaked marking or something I don't know about
Started by Mel Larsen, August 02, 2012, 06:50:53 PM
Mel Larsen
I bought a Proto box/open ended wrench at a yard sale that is marked" 5/16 1210-W PROTO mfd. U.S.A. 5/16 " BUT it measures 5/8" on both ends.  I guess they make mistakes once in a while.
Mel
OilyRascal
with the right marketing, you're bound to get at least $2m for that on eprey.
rusty
#2
Often when the wrench part number has a 'W' in it, the wrench is marked for Whitworth sizes...
(5/16 Whitworth is .600 , 5/8SAE=.625)
Mel Larsen
#3
Well I joined this forum to learn and today I learned that some crazy guy named Whitworth doesn't know how to measure.  It's tough enough for us old guys so they don't need to add to the confusion with "Whitworth"  I say we outlaw it.
Mel
lbgradwell
Papaw
Please google Whitworth and learn about the system. Truth be told, it may have been a better one than what we use now.
QuoteThe Whitworth thread was the world's first national screw thread standard [1], devised and specified by Joseph Whitworth in 1841. Until then, the only standardization was what little had been done by individual people and companies, with some companies' in-house standards spreading a bit within their industries. Whitworth's new standard specified a 55° thread angle and a thread depth of 0.640327p and a radius of 0.137329p, where p is the pitch. The thread pitch increases with diameter in steps specified on a chart. The Whitworth thread system was later to be adopted as a British Standard to become British Standard Whitworth. An example of the use of the Whitworth thread is the Royal Navy's Crimean War gunboats. These are the first instance of 'mass-production' techniques being applied to marine engineering as the following quotation from the obituary from The Times of 24 January 1887 to Sir Joseph Whitworth (1803-1887) shows:
http://en.wikipedia.org/wiki/British_Standard_Whitworth
Bill Houghton
Quote from: Papaw on August 02, 2012, 07:57:29 PM
Well yes, but having wrenches that don't just specify the wrench by the shank size of the bolt, but specify two (or three) different bolt diameters, depending on whether the threads are coarse or fine pitch, would seem challenging on a daily basis.  I guess it's like everything else: you'd get used to it.  But when the bolt's installed, you can't tell pitch.  I like being able to look at a bolt head and grab the right wrench.
mrchuck
The Austin Healey that I had way back was all Whitworth.
You get used to it.
Have you noticed that most new cars today are metric?
Same with almost anything that has a lot of bolts, oops,,,"fasteners" on it.
The time is passing,,,,,,,,
Molon Labe
Wrenchmensch
#8
Here is a King Dick (A UK name, don't you know) Whitworth-based wrench.  The 7/16 W opening is 13/16", and the 1/2 W is 15/16".  It's more-or-less the same size and shape as an old Dodge "4" or "5" wrench.   I have placed a Dodge "5"   (1"x15/16") wrench below it for comparison.  I suppose the King Dick was also intended for general automotive use use on English cars and trucks back in the day (1940 - 1970).
I hope one of the experts on this site gives us a better estimate of the ages of these plain Jane wrenches.
1930
#9
Its not just Dodge but all CPDD vehicles between 1929 and 1936 or so. Was part of the original toolkits but specific models, specific years, specific lines of trim
strik9
My boss was trained by men who used USS standard wrenches.   Even though I knew tools he asked for a 3/8" and I would have to give him the 9/16", he really thought everyone knew the conversions right off the top!
I learned the common conversions before I learned that it was a retired standard from the 20's.
Oddly he slowly changed out all his older tools for new Wurth stuff and now asks for the closest metric by head size for SAE and metric applications.
All this learning curve caused me to become a collector of alternative marked DOE tools when I find them.   Early metrics seem to be the biggest challenge and then Whitworth.    I also have 3 Eagle Brand  marked in SAE A/F and SAE decimal.   First I've seen of that and I'm lucky enough to have 3 of a set already.   Seems to have been a British sort of standard that faded out fast.
Wrenchmensch
Hm Wrench
Always Looking for Motorcycle, Bicycle tools and related information.
scottg
Quote from: mrchuck on August 03, 2012, 10:04:16 AM
I was in the second grade when they came to my school one day and announced,
"The Unites States is going to go to the metric system."
Lately though, for the first time, I have begun to be able to "think" in metric. At least some.
The trick for me is to remember something of a known measurement. I wear a 4mm ring. Its easy to look down and guesstimate other small measurements just from that.
The 10mm wrench has become so universal I can spot one offhand, from a distance.
  Several things like that.
I doubt it will ever be like Imperial wrenches where I seldom need to look at the size marking at all.
But I will be grateful to ditch the obnoxious fractions of precision measurement conversions in my head.
  Let's see, 1/16 = .064.
Yeah I need 100 of those floating around taking up precious grey matter.
PHounding PHather of PHARTS
Wrenchmensch
I picked up some Austin-Healey wrenches.  I once bought a new Austin-Healey 3000 MkIII, and I recall these were the kinds of wrenches that came in the car's toolkit.  Both wrenches are embossed with the Austin script and the Whitworth sizes on either open end.  The smaller wrench has open ends marked 3/8 and 5/16.  It is also marked A2.  The larger wrench has open ends marked 1/2 and 7/16; these are the same sizes as the ones on the King Dick DOE wrench I posted earlier (above).  Though they are Whitworth-sized, both wrenches lack the Whitworth W mark.
I included a photo of the maker's boss on the back of the larger wrench. Perhaps someone can decipher it for the rest of us.
