Author Topic: 18.5" monkey wrench is a Whitman & Barnes.  (Read 3242 times)
« on: September 28, 2012, 04:34:18 AM »
Finally replaced the old burnted wood handles on my monkey wrench.
How it looked before
Marked wood & bandsaw cut outside of 1/8" line, then cut ~45 deg. from edge.
Used belt sander to rough sand to shape (still ~1/8" oversize)
Drilled 5/16" hole & 1/2" counter for bolt, ground hex round on nut & bolt, hacksaw shallow slot for screwdriver.
used burr grinder to cut hollows in wood to match handle protrusions.
trial fit nut & bolt, & filed handle to fit the tang & taper ends. assembled with epoxy glue.
beltsand excess wood & bolt/nut flush to handle.
handsand finish, used tongue oil 1st coat...
Re: 18.5" monkey wrench is a Whitman & Barnes.
« Reply #1 on: September 28, 2012, 04:38:44 AM »
Continued due to 800K limit..
« Last Edit: September 28, 2012, 07:13:07 PM by oldtools »
« Reply #2 on: September 28, 2012, 05:12:00 AM »
Awesome job! Looks great!
« Reply #3 on: September 28, 2012, 06:15:41 AM »
Great job!!
Well. fellow PHARTS, do we put him in the club, or wait till he does an H D Smith one?
« Reply #4 on: September 28, 2012, 08:08:16 AM »
Nice work! Let it be known throughout the land that oldtools is given the title of
« Reply #5 on: September 28, 2012, 09:48:15 AM »
What kind of wood did you use?   Something Hawaiian?  Great job!
« Reply #6 on: September 28, 2012, 11:16:26 AM »
Good job!
Close enough for the pharts I run with! 8^) heh
 And yeah, you can't post a restoration without divulging the wood choice??
It does look kinda Polynesian to me too.
Offline DM11
« Reply #7 on: September 28, 2012, 12:56:48 PM »
Nice restoration!
Hold Fast
David
« Reply #8 on: September 28, 2012, 03:24:52 PM »
My niece gave me ~100 planks of this used Hard wood floor, 18" to 40" long.
I have been using it to make custom wood signs & nameplates with my scrollsaw, also notched & fit wooden cross.
MERBAU
INTSIA PALEMBANICA
Merbau is a popular timber for joinery applications in Europe. Its grain and growth ring figure together with its dark red-brown color gives it a very attractive appearance which is suitable for high class joinery including door and window frames and facades. The timber is also used for interior paneling, strip and parquet flooring and other decorative uses. Merbau is a very hard timber with a truly special beauty. ALSO TERMITE RESISTANT
FAMILY
Caesalpiniaceae.
OTHER COMMON NAMES
Ipil, Quila, Lumpha, Lumpho, Tat-talun, Vesi.
ORIGIN
Indo-Malayan region, Philippines, Indonesia, Australia and western Pacific islands.
« Last Edit: October 08, 2012, 01:14:56 AM by oldtools »
