Whatzit Doozies Part 2
Started by dimwittedmoose51, January 11, 2013, 04:05:43 AM
dimwittedmoose51
The top item appears to be some sort of spring compression tool, but the cotter pin and the two spare tips have me baffled.  Any ideas what application this thing has in the world of springs??   Or am I way off base here??
Bottom item appears to be a packing nut speed handle.  Anyone confirm or deny that?
TIA
DM&FS
Champion Pawn/Flea Plunderer
OilyRascal
Billman49
Used on old side valve engines - where you could compress the spring against the engine block - it's a long time since I used one of these..
1930
I could use those if they are avail, I also like the red handled phillips screwdriver if avail.
