Am I really considering this......
Started by Nolatoolguy, January 11, 2013, 09:32:36 PM
Nolatoolguy
I have a chance at a old crescent table saw. I only got a couple problems.
No space, my dad already hates the fact Ime taking up half the garge. Second it would be a tight on the wallet to purchase better yet get running. The last big problem is I have no idea how I get it home.
Well i am considering, any thoughts.
skipskip
Thats a monster saw.
a great collector item, but I have no facts about how well they cut.
It's on a trailer maybe the owner could deliver it?
RedVise
sounds like a project start, not an immediate available working tool.
Brian L.
Neals
A lot better to consider before you buy than after you buy. I've tried it both ways.
Bus
Is that a wrench hanging on the side? Is it marked?
HeelSpur
That's an industrial grade table saw.  How big a blade will it swing?  Looks like a five horse motor, and I'll just about guarantee it originally ran on  a line-shaft system -- it was meant to.  No contractor table saw will begin to compete with what this will do.   This is what you find in a mill shop.
What a beauty!  If you can manage at all, this is THE SAW.
wrenchguy
r u  familiar with http://vintagemachinery.org/  the woodworking machinery pages r the best.  good luck
wrenchguy
Quote from: Branson on January 12, 2013, 07:54:51 AM
i'd say with its one piece extended cast base its very early electric motor setup.
Brophy
That is a once in a lifetime find....and with the matching sander???
Awesome. Just frickin' awesome.
...Rob
Gray Tool Box WINNER!!!
Nolatoolguy
As of now Looks like I won't be getting it.
Ietech
#11
Quote from: wrenchguy on January 12, 2013, 08:22:01 AM
Branson is correct but if it is 5 hp you better check that your elect panel will need a dedicated breaker/dual breakers, you will need a 40 amp 240VAC breaker and the motor will draw 22 amps under no load, locked rotor /startup will be significantly higher for a few seconds.  It is also possible that it is 3 phase and that is another ball of wax.
Don't get in over your head there are plenty of 110/120 VAC saws available at a good price and don't need any special attention. Of course if you want a learning project I think you just met a possible challenge. Good luck with that one --- it's kool but I wouldn't touch it with a ten foot pole, not even if it was free. JMHO -- If you really need a saw buy something that will run on existing elec available. If you want a long term project I think you found it. Old is Kool but "Function Rules" if you need to use it.
BTW I work with a guy who worked in a mill for ten years in the 60s/70s and he said that it probably used in a mill but it was a very small saw and he had never seen one that small actually in the mill he worked in northern CA. He said for normal everyday use and possible transportability to a job site it was pretty useless for a regular guy doing regular construction work. It's a fun project tho
Newest member of PHARTS -  Perfect Handle Admiration, Restoration and Torturing Society
Ietech
Quote from: skipskip on January 11, 2013, 09:45:41 PM
Just curious how much are they asking for it --- ok if you don't want to reveal the price just curious
Nolatoolguy
Quote from: Ietech on January 13, 2013, 12:15:40 AM
Guy said on phone 150$ picked up no delivery.
oldtools
Quote from: Brophy on January 12, 2013, 09:00:37 AM
Was the Belt Sander & Drill Press part or the deal?
