Author Topic: Bowes seal fast tire repair tool, but what it do?  (Read 5302 times)
« on: January 13, 2013, 12:42:37 PM »
Bowes is still in the tire repair business, but I can find this one.
any hints?
JAN 044 by skipskip, on Flickr
Re: Bowes seal fast tire repair tool, but what it do?
« Reply #1 on: January 13, 2013, 01:35:56 PM »
Brake shoe holder?
Is is spring loaded with a lock ?
Offline krusty the clown
« Reply #2 on: January 13, 2013, 01:38:14 PM »
Tire spreader?
« Reply #3 on: January 13, 2013, 01:58:56 PM »
Brake shoe holder?
kinda not, seems too weak, and works inside out for that
yes
« Reply #4 on: January 13, 2013, 01:59:50 PM »
Tire spreader?
maybe, but kinda wimpy for that, I was thing tube spreader to make patch repairs?
« Reply #5 on: January 13, 2013, 02:47:53 PM »
It is a tire spreader, back in the days of a tire size of: 7:00 x 15  the sidewalls came within 2 inches of each other.  It just made it handier to open it up to put in a patch.  Or a boot, which was a big heavy patch.   In a gas station the same thing was done with a pair of arms on a stand, with a lever to pull the sidewalls outward.
« Reply #6 on: January 14, 2013, 04:08:09 AM »
Now if it was in wood, it would be a hat stretcher....
« Reply #7 on: January 14, 2013, 06:47:16 AM »
Billman is correct, it is a HAT stretcher
« Reply #8 on: January 14, 2013, 08:12:10 PM »
OK, looks like a hat stretcher, but  BOWES SealFast hat stretcher?   Is the name on it?   Why would a hat need to be sealed fast?  hmmm.    Bowes to me rings an a bell for a radiator stop leak treatment now that I ponder on it.
« Reply #9 on: January 14, 2013, 08:16:22 PM »
What, you don't own a waterproof rubber hat?
« Reply #10 on: January 17, 2013, 02:47:58 AM »
Looks like a wheel holder for installing forklift tires.
Back in the time after Fred Flintstone retired, and before hydraulic tire presses, the tire was boiled and slipped onto the wheel sitting on the floor where it shrank onto the wheel.
« Reply #11 on: January 22, 2013, 07:44:23 PM »
Hat stretchers were made of wood and had a threaded handle in the middle so that you could put pressure on the curved pieces and thus make the hat larger.  These were usually put in place and left overnite.  If necessary you could repeat until the size was correct.  They weren't made to stretch a hat very much.  I used to use one occasionally when I worked in a clothing store as a kid.  Not many felt hats sold any more.
It seems to me that there was an Indy car that was called the Bowes Seal Fast Special.  Don't remember who drove it.  Found it!  See below.
http://www.mecum.com/auctions/lot_detail.cfm?LOT_ID=CA0811-117667
http://generalracing.com/kurtis                The one A.J. Foyt drove.
« Last Edit: January 22, 2013, 07:50:39 PM by mikeswrenches »
