Author Topic: Tool with mirror. Hi--  (Read 2746 times)
Offline drsam999
« on: January 19, 2013, 05:18:45 PM »
 I just joined this forum. I picked up a mirror--it looks like it had some handles for moving it into difficult places. Does anyone know what it is? It's only 7 inches high by 3.25 inches wide--but heavy. It weighs over 5 pounds.
I searched the serial number-but with no luck-- 16020088. Thanks.  drsam
Re: Tool with mirror. Hi--
« Reply #1 on: January 19, 2013, 05:32:09 PM »
That is a front surface mirror with a temperature compensated holder. It belongs on an optical bench with a laser or such...
(Sorry, there are thousands of variations , and I can't ID that specific one)
General info:
http://en.wikipedia.org/wiki/Mirror_mount
(PS: It very likely was once VERY expensive, tho, if the morror is scratched, it isn't so much anymore;P)
« Reply #2 on: January 19, 2013, 10:20:15 PM »
wanna explain that for those of us that didn't finish technical school  :)
Skip
« Reply #3 on: January 20, 2013, 09:56:25 AM »
An optical bench is something you would find in a research lab. It is a flat,sturdy table that you can experiment with light on. For example, you might have a laser on it, with some mirrors and lenses and such to study how light refracts, or reflects or any other interesting thing you might want to do with light....
Mirrors, lenses, prisms, color filters etc are all available with mounts to go on the bench so you can arrange them however you like to do whatever it is you are doing with light...
The mirror above is 'front surface', meaning the silvering is on the side you are looking at , instead of the back. Normal mirrors put the silver on the back so the glass will protect it, but that means the light reflected in the mirror has to pass through the glass twice, and some of the light is lost in the process, and the color changes slightly.
For precision mirrors, the silver is on the reflecting side so that doesn't happen. (however, it is not protected, so the mirrors are very easily damaged)
Offline amertrac
  • ny mountain man
« Reply #4 on: January 20, 2013, 11:21:18 AM »
I used to use a mirror on a stand to sdjust the toe-in on the older cars. cause of that old saying you can;t be in two places the samr tine   bob w
