Author Topic: Yesterday's Find  (Read 2396 times)
Offline Wrenchmensch
Yesterday's Find
« on: January 20, 2013, 02:43:55 PM »
For years I've had a G. M. Company's combination monkey wrench, tack remover, and hammer hanging on one of the wrench boards. I considered it a flawed wrench because the lower wrench jaw was not attached to the handle. Yesterday I found a second one of these. I picked it up and the jaw remained attached. There was a piece of spring metal stuck out-of-sight between the lower jaw and the handle. I bought it ($8). This afternoon I discovered the spring clips into the slot in the back of the jaw thereby stabilizing the jaw and making jaw adjustments much easier.  A real Eureka! moment.
Re: Yesterday's Find
« Reply #1 on: January 20, 2013, 04:24:25 PM »
The sawtooth rack makes it a quick adjust wrench, but without the spring is is going to be a quick unadjust wrench also.
Hmm....
I soppose if the spring can fall out, it's not so unbreakable after all LOL
Very classy wrench :)
PS: I'm almost certain that wrench is patented...
Offline anglesmith
« Reply #2 on: January 21, 2013, 01:01:44 AM »
Good find! Can you now make a replacement spring for your original one?
Graeme
Offline Bus
    • The Wrenchingnews
« Reply #3 on: January 21, 2013, 10:48:00 AM »
Design patent No. D172,968 was issued to George Iskyan of Jackson Heights, NY on Sept. 7, 1954.
http://www.datamp.org/patents/displayPatent.php?number=172968&typeCode=2
« Reply #4 on: January 23, 2013, 10:54:34 AM »
Thanks, Bus!
« Reply #5 on: January 23, 2013, 09:43:29 PM »
I've been asked for spring dimensions for this wrench.
The spring dimensions are:
Thickness:   .00275 in.
Width:         .250 in.
Length OA:1.578125 in.
Length Tab: .109375 in.
Notes: the exposed end of the spring is cut in a shallow radius with its highest point .0625 in. above a straight line across the spring's width. The tab is square cut.  The spring's overall curvature and the end bends can be seen from the photos.
« Last Edit: January 23, 2013, 10:53:21 PM by Wrenchmensch »
