Author Topic: Can anyone tell me what these old tools are?  (Read 2741 times)
Offline barbb0
« on: October 01, 2013, 03:13:21 PM »
The pointed one is 3 1/4" long and 3/4" round.  The larger one is 3" long and 1 1/2" round.
Thanks,
Barb
Re: Can anyone tell me what these old tools are?
« Reply #1 on: October 01, 2013, 04:26:22 PM »
The pointy one looks like a lathe center and the one with the set screw looks like part of an extension for making auger bits longer.
« Reply #2 on: October 01, 2013, 04:36:20 PM »
I don't think the pointy one is a lathe center.  A lathe center would have a Morse taper where the knurling is.  Unfortunately I don't know what it might be.
Offline superzstuff
« Reply #3 on: October 01, 2013, 04:39:36 PM »
Lathe centers are 60 degrees, that looks like 90, and it has been hammered on end and knurled. I would guess a center punch to locate drilled hole. Not sure about the other with set screw. Since it is knurled and has many holes must be for turning or twisting something.
« Reply #4 on: October 01, 2013, 05:25:54 PM »
The one with the thumb may be a drift, designed to hold a piece of drill rod.
The pointy one looks kinda wide to be just a center punch, perhaps for driving out a piston with a center already in the middle or such...
Offline JessEm
  • MinneSNOWta
« Reply #5 on: October 02, 2013, 10:46:08 PM »
FWIW it kinda looks like a tool that could be used for dowel joinery.
Offline JessEm
  • MinneSNOWta
« Reply #6 on: October 03, 2013, 09:07:07 AM »
I take that back... It looks similar to a packer drill attachment, included in a late-teens Starrett pressed-steel socket set.
Fig. 230 shows the unmarked drill attachment shown with the early Starrett No. 443-A socket set. The drill attachment consists of a 5/8-drive adapter threaded to screw into the knurled body, and the drive end of the adapter has a tapered square opening (not shown) for holding the drive stud of an older-style drill bit.
The overall length is 5.1 inches in the retracted position. The finish is plain steel.
« Last Edit: October 03, 2013, 09:10:14 AM by JessEm »
