Author Topic: King Rack Wrench  (Read 3607 times)
King Rack Wrench
« on: October 13, 2013, 04:59:14 PM »
Martin Donnelly auction lot #700 in the up coming October 26th auction is listed as a King Rack Wrench Patent #X7254. The first picture is from Martin's listing. It doesn't look like the patent drawing but then again many actual items don't match the patent drawing. The DATAMP listing pictures a wrench like the second picture. Do any of you have any additional info to lend on these two wrenches?
There is a later patent X8153 issued to Solomon Merrick in 1834 that is similar to the King patent.
Offline mvwcnews
Re: King Rack Wrench
« Reply #1 on: October 13, 2013, 05:55:55 PM »
Having done the DATAMP entry   for patent no. X7,254, the wrench example shown  in the 2nd image  is from one of the well-known top end collections, and the markings cited are visible on those examples.
Donnelly has had one of the "exaggerated lever" types in a sale at least once before --  I have not personally seen one to know where it fits in.  Given the tendency of early wrench patent drawings to match the appearance of the production tools (the Scripture wrench being a notable exception), I wonder exactly where it fits in that long gone world of  inventor / makers.
Regards, Stan S.
« Reply #2 on: October 13, 2013, 07:11:28 PM »
If you squint at the script in Merrick's description, it says the patent is an improvement on Kings patent, adding a groove for something to do with the spring (what I can read of it) , so I would expect both to look very nearly identical....
« Reply #3 on: October 13, 2013, 08:01:40 PM »
Merrick's improvement: - It's all about the ferrule...
Specification of a patent for an improvement on the Rack Wrench patented by Henry King. Granted to Solyman Merrick, Springfield, Hampden county, Massachusetts, April 18, 1834.
To all whom it may concern, be it known, that I, Solyman Mer rick, of Springfield, in the county of Hampden, and state of Massachusetts, have invented an improvement in the Rack Wrench invented by Henry King, and for which letters patent of the United States were granted unto him, on the 25th of October, 1832; and I do hereby declare that the following is a full and exact description of my said improvement.
The main bar, the slide, and the spring click, may be made in the same form and manner as those in the original Rack Wrench upon which this is an improvement; but instead of cutting the notches in which the spring click is to catch, directly upon the main bar, I make a sliding rack, of such length as may be necessary to regulate the distance of the jaws from each other, which rack 1 place in a groove on the upper side of the bar. Upon this sliding piece I cut teeth, or notches, to receive the spring click, either at equal or at graduated distances from each other. This sliding piece, or movable rack, is to be acted on by a screw, which must cause it to traverse backward and forward to a distance equal to that of the widest tooth in the rack. What I deem one of the best modes of arranging the parts so as to accomplish this end, is the following.
I make the shank of the bar, or that part of it which passes through the handle thereof, round, and form a square shoulder at the point where the square bar commences; over this round part I drive a turned collar, which bears against the square part of the bar, and there forms a flanch, which keeps one end of a nut, or ferule, in its place, which passes on to, and revolves freely against it. A groove is made through this collar, to correspond with that on the main bar, that the rear end of the sliding rack, before described, may pass through it. On this end of the rack, spiral grooves are cut, which match into the threads of a female screw cut upon the inside of the revolving nut, or ferule, just alluded to. This revolving ferule is then passed on to, and against, the aforenamed collar, being screwed round so that the threads on its inner surface may take on to spiral grooves, which form a segment of a male screw on the end of the rack. Another circular collar, of the same diameter with the former, which is equal, or nearly equal, to that of the revolving nut or ferule, is then driven over the shank, and against the nut, but not so closely as to interfere with its revolving motion. The wooden handle may then be driven on the shank, and rivetted in its place. The outer surface of the nut should be milled, that it may be the more readily turned round by the hand.
It will be seen that, by this arrangement, whenever the slide is placed to the nearest desirable point on the rack, the jaws can be readily and precisely adjusted by turning the nut.
Although I have pointed out what I deem to be the best mode of arranging the parts so as to adjust the sliding rack, I do not intend thereby to confine myself to this particular arrangement, but to vary the same in any way which is in accordance with the general principle or mode of action hereinbefore set forth, and by which a similar effect is produced; limiting myself, in my claim to improvement, to the addition of the movable or sliding rack, operated upon, and adjusted, by a screw. Solyman Merrick
Offline Bus
    • The Wrenchingnews
« Reply #4 on: October 17, 2013, 01:34:48 AM »
Rusty,
Did you find that transcription of the Merrick wrench patent or did you do it yourself?
« Reply #5 on: October 17, 2013, 01:49:33 PM »
I think it is pretty close to what the patent says. If you look at the patent and enlarge the pages you can read it easier. The cursive handwriting is hard to read.
« Reply #6 on: October 17, 2013, 07:11:05 PM »
Sorry, forgot the credit, it's from an issue of the Journal of the Franklin Institute, They typeset many of the early hand written patents when the Patent office issued them, but without patent numbers it is kind of a challenge to find them...
http://books.google.com/books?id=f58EAAAAQAAJ&pg=RA1-PA340&lpg=RA1-PA340
« Reply #7 on: October 28, 2013, 06:51:44 AM »
Consensus among the most knowledgeable wrench guys I know was this isn't a King Patent wrench but it sold for $1,200.00 anyway. The restoration was done by Herb Page. I got outbid on all of my absentee bids, heading to Browns Auction and sale the end of the week in Camp Hill PA.
« Reply #8 on: October 28, 2013, 06:49:50 PM »
Ouch....
There was a comment with that patent article mentioning that the wrench (Merrick's) was better than 'similar imported wrenches'...wonder if it's from UK or ..???
Offline Bus
    • The Wrenchingnews
« Reply #9 on: October 29, 2013, 12:18:08 PM »
i saw this wrench before the wooden handle and some other modifications were made and it had a piece of iron pipe for a handle. Pretty sure it is an American shop made wrench.
« Reply #10 on: October 29, 2013, 08:01:26 PM »
I looked at it quickly, but never picked it up to give it a close inspection.  This thing was 24 in. Long and I usually don't bother with these big guys...especially at that kind of price.  There were some other rare wrenches that fetched good prices.
