The slide at the bottom looks like those found on an old hand mortiser to adjust the position of the chisel - some also had a drill to partially remove the core of the mortice before the chisel was used. The central spring and the two pullies with the leather straps looks like it could be some sort of return mechanism, to aid the user. However, never seen a hand mortiser with return spring assist.... So will keep looking/thinking...
