Author Topic: Micro Master or Master Micro?  (Read 3793 times)
« on: January 20, 2013, 06:21:54 PM »
I picked this up a while ago, but am no closer to learning anything about it.  It says "Pull Back" but nothing moves.  Three detent depressions on the side of the hex shaft.  "Made in U.S.A.  Pat Pend," "Master Micro," and "Pull Back" are all I can find besides somebody's scratched in "XMTT" on the handle.
It's heavy and seems well made.
Anybody know this one?
Re: Micro Master or Master Micro?
« Reply #1 on: January 20, 2013, 06:55:19 PM »
Square shanked, with dimples. Thinking it is a screw holding screwdriver missing the outer tube shaped piece that you would 'pull back' to open the screw holding fingers at the tip....
(a way to escape the split shanked patent)
« Reply #2 on: January 20, 2013, 07:22:31 PM »
What Rusty said.  All sorts of them that I've found; Quick-Wedge, Greenlee, Klein, Craftsman, yankee
« Reply #3 on: January 21, 2013, 11:50:12 AM »
Hex shanked though.  It looks to me as though the shank could be withdrawn into the handle -- there's about an inch and a half of empty space at the
back of the handle.
« Reply #4 on: January 21, 2013, 12:00:24 PM »
It may be helpful to have a view dead on of the working end, right where the shank goes into the handle.  It does look as if that metal on the end would sleeve out - maybe allowing the shank to be removed?.
Also look at "hex-a-matic" (auto adjust nutdriver) to make sure it isn't same or similiar
« Reply #5 on: January 21, 2013, 04:22:37 PM »
No luck with hex-a-matic.  Found one hex-a-matic sold on eBay,  No resemblance at all, drat.
« Reply #6 on: January 21, 2013, 05:23:58 PM »
Does the ferrule unscrew from the handle and release the driver?
Looks like a collett handle.....
« Reply #7 on: January 22, 2013, 09:02:53 AM »
I'll try that next.  The ferrule says "pull back," but there doesn't seem to be any room to pull it back.  I like the screwdriver -- it feels hefty and strong.  It was in a tool box I got at a flea market a while back.
« Reply #8 on: January 22, 2013, 04:43:48 PM »
perhaps towards the blade?
« Reply #9 on: January 23, 2013, 08:49:34 AM »
That's where there seems to be no room to pull back.  I'm perplexed.
« Reply #10 on: January 23, 2013, 08:53:27 AM »
Oops. I misread what you wrote, Rusty.  I tried that first, but nothing wanted to move.  Maybe it's just bound up and needs a soak.
All might become clear if I could identify the manufacturer -- no luck so far on that head.
